is there a way to output AOVs only without rendering beauty etc? Since they are calculated in sync with main rendering is there a fast output way other than put like 1 sample into pathtracing etc?
Render AOVs only
This is probably not possible because render passes are generated during rendering as side product. Technically beauty pass is a mix of all other AOVs. But simple masks should be generated without the need of final rendering - as it is in CPU renderers.
You can't have anything without main render buffer. Just use maxsamples low as giving acceptable outputs.ceen wrote:Yes most likely. Do you know how to render layer masks and MatID, ObjID etc only?
