OctaneRender™ for Blender 2021.1.1 - 25.0 [TEST]
azen
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to Blender 3.0
  • Upgraded to 2021.1.1
  • Supported the "Cinema4D Noise" node
  • Supported the new Cryptomatte passes
FIXES SINCE LAST RELEASE
  • Fixed the default value of "work chunk size"
  • Bug fixes
You can read about new features of OctaneRender™ 2021.1.1 here:
viewtopic.php?f=24&t=78954
1. OctaneRender™ Server
Windows
Blender Octane Edition - 25.0 (3.0)
Octane Server - Enterprise Edition - 25.0
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 25.0 (3.0) Linux
Octane Server - Enterprise Edition - 25.0 Linux
