OctaneRender 2021.1 for Houdini production build 2021.1.1.0
juanjgon
This is a production release of the OctaneRender™ 2021.1 for Houdini™ plugin compiled with the Octane 2021.1.1 core. This 2021.1.1.0 release is available for the latest Houdini production builds on Windows x64 and Linux gcc6.3.1.
Houdini production builds supported by this release: 17.5.460, 18.0.597, 18.5.696, 18.5.759, 19.0.383 and 19.0.455
This version supports Nvidia Ampere GPUs and as a consequence, we had to drop support for old Kepler cards with a compute model < 3.5. And please make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux
New features
To learn more about the new features and improvements of OctaneRender 2021.1, please check out the 2021.1 release post
Release 2021.1.1.0 Enterprise subscription license
https://render.otoy.com/customerdownloa ... rprise.zip
Release 2021.1.1.0 Studio subscription license
https://render.otoy.com/customerdownloa ... studio.zip
Release 2021.1.1.0 Demo version license
https://render.otoy.com/plugindownloads ... 4_demo.zip
https://render.otoy.com/plugindownloads ... x_demo.zip
Standalone 2021.1.1 version for the network rendering nodes
viewtopic.php?f=24&t=78954
Release Notes
RELEASE 2021.1.1.0
* PLUGIN FEATURES AND FIXES:
- Added H18.5.759 and H19.0.455 plugin builds.
- Addressed a problem while creating VOP texture nodes with the IPR enabled.
- Fixed a problem in the render target HDA related to the volume AOVs.
- The Octane material builder node is now created including the Octane universal material node inside.
- Updated the defaults of some ROP parameters to match the most common production settings.
- New option in the OBJ spare parameters to ignore the pivot point attribute, enabled by default to resolve xform problems with the packed geo instancing.
- Fixed a problem in the hair rendering with very low "width" point values < 0.0001
- Added support for custom object AOVs.
- Added the "Cinema 4D Noise" shader node.
- Refactoring of the Cryptomatte AOVs to support material and object IDs from the Houdini node paths, custom OBJ IDs and layer/instance IDs.
- Refactoring of the scene cleaning code to hopefully fix some rare crashes while rendering sequences in full scene reload mode.
* OCTANE 2021.1.1 FEATURES AND FIXES:
- Added Cryptomatte AOVs for mattes based on the render layer, user instance ID and geometry node name of an object.
- Brought back the option "Emulate old volume behaviour" to the kernel nodes.
- Added a small offset to cell noise and the checkerboard texture to avoid artefacts on axis aligned planes that lie exactly on the face of a checkboard / cell cube.
- Overhauled the way how render work is distributed to local and remote GPUs: The main idea is to reassign already assigned but unfinished work to available GPU when there is no more unassigned work left. This avoids that net rendering may hang due to unfinished work, because some intermediate result got lost. It may also reduce the render time when the local GPUs are out of work but Octane is still waiting for one or more render nodes to finish and return their result.
- Fixed clipping material that is a vectron mesh not working correctly as it casts shadows over other materials its clipping.
- Fixed emission with "Visible on diffuse" disable still being visible on universal materials with a coating.
- Fixed render failure on render nodes if AI light is enabled for sphere light primitives.
- Fixed render failure in scenes with mix materials when clay mode is enabled.
- Fixed render hang if you use an environment texture that uses the "Sample position" texture and if "Importance sampling" is enabled.
- Fixed render failure when you use a texture with projection "Sample pos. to UV" for vertex displacement.
- Fixed light linking through transparency surfaces giving unexpected results.
- Fixed incorrect Vectron® bounding boxes if there are object layer maps in the node tree.
- Fixed noise pass not applying gamma when an OCIO view is selected.
- Fixed denoiser not working on CPUs without AVX support.
- Fixed mismatch between the main AOV with post FX enabled and the composite of the main AOV with the post-processing AOV.
- Fixed failure to write OpenEXR files to paths that contain characters that are not in the current ANSI code page.
- Fixed render timer not starting if no local GPUs are used for rendering.
- Fixed the cuDNN download for the demo version on systems that didn't run OctaneRender before.
- OSL: Fixed raytype("shadow") for volume scattering and absorption textures.
- OSL: Fixed referencing of vertex attributes via unconnected OSL input variable.
Happy rendering,
Your OTOY Team
james_conkle
Thanks Juanjgon! Great to see things like standard settings being updated and materials come in ready to go. I really appreciate anything that makes H more artist friendly :D
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
Terryvfx
thanks for the release!
Sportler
Thank you!
GPU: 1x Nvidia RTX 3080 Ti
RAM: 64GB DDR4 3200MHz
CPU: 5950x
vurt
Hey @Juanjo
Thanks for the hair fix.
But it broke everything. You've clamped too high.
I was using the temporary solution with adjusting the minimum scale, it was working fine. But my object is small. So I can't go now below your minimum value.
Please fix. Meanwhile rolled back to previous build
juanjgon
Hmm, do you need width values below 0.0001? ... I'm not even sure how stable this rendering could be due to the floating precision limits artifacts, but, well, I'll change it to 0.000001, that probably is the true limit for Octane.
juanjgon
I can send you a custom plugin build with this update. I only need to know your license type and your Houdini version.
vurt
juanjgon wrote:I can send you a custom plugin build with this update. I only need to know your license type and your Houdini version.
Thanks, I have two studio and one Enterprise lics. H19.0.455
juanjgon
vurt wrote:
juanjgon wrote:Thanks, I have two studio and one Enterprise lics. H19.0.455
Ok. Check this new build:
https://render.otoy.com/customerdownloa ... _rev02.zip
vurt
Thanks, Fixed
