If you drag an HDRI from the Asset Library to the Environment Tag the image doesn't take effect.
It will work if you drag the same HDRI file from elsewhere, just not the new Asset Library.
Thought it would be worth mentioning. Loving the other advances in PR13, material editing is much better (less crashes and more fluid).
Using Mac, Monterey, PR13 C4D S24 and R25.
Small bug with Asset Library and Environment Tag
It's not a bug but unsupported case. Because current Mac builds are on old codebase, will be fine when 2022 comes up to Mac
