It is just a few cylinders with a mix material.
When I want to make a "clay render" in octane viewport, viewport close.
Can you confirm ?
I have a crash of octane then with max with clay render
- Attachments
- TEST.zip
- (1.74 MiB) Downloaded 157 times
- neonZorglub
Hi HHbomb,HHbomb wrote:Hi,
Can you confirm ?
Thanks for reporting this issue.
It's seems to be an engine issue. The clay mode causes Cuda errors with some mix material..
The engine team will work on a solution.
