Combining 2 Nomal Map with Composite Node Texture
samsue
Hey guys ...
Quick question... if I want to add 2 NM how would I do it in Photoshop with overlay if I am not mistaken. Which Blende Mode should I use?
paride4331
Hi samsue,
Did you try using the composite texture node?
Regards
Paride
samsue
Hey paride!
Yes I am using it... but the overlay does not look right, as it will in photoshop.
i did some tests that it seems to work. but i wanted to know what the correct one is
Return to “Autodesk 3Ds Max”
