Is there a way to render something that you made with Cinema 4D's Scene Nodes?
I get an empty live viewer. There also no Octane Geometry node or anything in Cinema's Node Editor?
Is there a work around, or is this a feature that is worked on? The Scene Node editor is very powerful and it would be great to use it in the future.
Cinema 4D Scene Nodes
It should work. Which version are you using?
I have a similar issue, I am using the Linear Arrow capsule (spline) in a extrude. The live viewer works flawlessy like the viewport but when I send to render it just renders the arrows at it's last keyframe.
Any idea how to get over this issue?
Using Octane Render 2022.1 with Cinema 4D 2023.1.3.
First thing I'd try is updating Octane to 2022.1.1_R5, and I think it needs C4D 2023.2. There is also a C4D 2023.2.2 update available.Vivimagic wrote:I have a similar issue, I am using the Linear Arrow capsule (spline) in a extrude. The live viewer works flawlessy like the viewport but when I send to render it just renders the arrows at it's last keyframe.
Capsules are virtually generating geometries. It should work if it's working in LV for my opinion. Please send me your scene to satisfy my curiosity.Vivimagic wrote:I have a similar issue, I am using the Linear Arrow capsule (spline) in a extrude. The live viewer works flawlessy like the viewport but when I send to render it just renders the arrows at it's last keyframe.
