C4D Hair Module In Cloner - Octane Live Viewer Errors
CalTrago
I am using C4D R23 with Octane and I have multiple objects with hair applied to them. The cloner is set as Linear and only showing 1 object at a time.
When viewed through the Octane Live Viewer I can see all hair modules at once, when there is only 1 visible in the C4D viewport.
If I change all hair modules to Generate > Circle then only 1 module is visible but with all colour remove.
If I convert all hair modules to an Object and delete all the original hair then only 1 module is visible. I need to retain all original hair splines though.
If anyone has any ideas on how to overcome this, they'd be very welcome! I have a deadline fast approaching and can't move forward until this is resolved.
Thanks, ay advice appreciated.
(I couldn't post in the C4D forum for some reason. Admins, feel free to move this post)
(can't post in the C4D forum for some reason)
I suspect that the issue is here.
How are you hiding the other objects?
Can you share some screenshots of the object manager structure?
ciao,
Beppe
Ok, it seems that you were able to write in the c4d forum and have support, great:
viewtopic.php?f=30&t=78853
ciao,
Beppe
