C4D Relink texture doesn't work
alexlomarco
Hello,
I'm trying to replace the textures of a kitbash3d scene, but it seems that the links are replaced only in the "bitmap" nodes and not in the "ImageTexture" nodes.
Here a video to explain that:
https://youtu.be/n1nI90Narvo
I managed to replace the path with Octane Texture Manager but it's a bit more inconvenient because it does not have the relink function
is there a way to make the c4d relink work?
Thank you
Alex
It's C4D's manager not Octane. It may not recognise our node. BTW haven't you tried our texture manager with replace function?
alexlomarco
yes, I used octane texture manager, but it's a bit more inconvenient because it doesn't have the relink function, but you have to write the path by hand in the replace field. But it works ;)
Thank you
Alex
alexlomarco wrote:yes, I used octane texture manager, but it's a bit more inconvenient because it doesn't have the relink function, but you have to write the path by hand in the replace field. But it works ;)
Thank you
Alex
it's same thing at the end. But you're doing it manually
