Image sequence loop in Opacity + X-Particles
jeremyshin
Hi guys,
I have a quick problem with an image sequence and X-Particles.
I want to use a few jpg images as a sequence in the Opacity channel of a material and set it to "loop" or "pingpong" but everytime that the sequence goes back to first image, it disappears.
I attached a simple scene example.
Thanks!
J
img_sequence_loop_opacity_xp.zip
(237.18 KiB) Downloaded 101 times
jeremyshin
Is there anything missing in my post that would unallow somebody to check my scene?
If so, somebody tell me and I will add more info.
Thank you
jeremyshin wrote:Is there anything missing in my post that would unallow somebody to check my scene?
Thank you
I was away from work, now checking. Could you please say why your images are just 0 and 1?
jeremyshin
No problem Aoktar!
I needed to make an animated sequence of binary numbers (0 and 1), thats why my images are 0 and 1.
jeremyshin wrote:No problem Aoktar!
Ok, "Loop" is giving the expected behavior for example.
18500214024fsy
jeremyshin wrote:Hi guys,
Thanks!
J
Hi jeremyshin,have you solved this problem?I'm facing the same problem .I'm trying to use a image sequence as the alpha channel,and this material is used on part of the polygons with another material warp it.But I can't find a way to make it work.
