Octane Solaris plugin 2021.1.0.4 - 10-30-21 [OBSOLETE]
BK
Dear Octane community,
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for Solaris V2021.1 - for Houdini 18.5.696.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrate completely with Houdini 18.5 Solaris.
What is OctaneRender for Solaris?
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
https://renderman.pixar.com/stories/pixars-usd-pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launching it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
New features
To learn more about the new features and improvements of OctaneRender 2021.1, please check out the 2021.1 release post
- Changes since 2020.2.5.0 - 10-13-21 [Test]-
  • Integrated Octane 2021.1 stable engine
  • Supports Collect node
-Known Issues-
- Octane 2021 UIs will be added in the next release
- Octane Color response is disabled because Hydra buffer expects linear output
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
Enterprise Subscription Downloads
2021.1 Houdini 18.5.696
Studio Subscription Downloads
Demo build Download
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
rohandalvi
Could we get a Houdini 19 build?
BK
rohandalvi wrote:Could we get a Houdini 19 build?
Hi Rohan,
Thanks for getting in touch.
It seems there is a bug in Houdini v19.0.383 that prevents us to make OctaneSolaris build.
We are in touch with the SideFx team to help investigate this issue.
cheers
Kind Regards
bk3d
rohandalvi
Thank you for the quick reply.
I hope the bug gets resolved soon.
Tokyomegaplex
also eagerly awaiting octane 2021.1 for solaris in h19! :)
BK
@rohandalvi and @Tokyomegaplex'
Yep, hope it gets resolved soon!
cheers
Kind Regards
bk3d
