OctaneRender™ for Blender 2021.1 - 24.5 [TEST]
azen
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to Blender 2.93.5
  • Integrated Octane 2021.1
  • Added the new cell noise texture
  • Added new pins in the clipping material
  • Added new pins in the noise texture
FIXES SINCE LAST RELEASE
  • Minor bug fixes
You can read about new features of OctaneRender™ 2021.1 here:
viewtopic.php?f=24&t=78621
1. OctaneRender™ Server
Windows
Blender Octane Edition - 24.5 (2.93.5)
Octane Server - Enterprise Edition - 24.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 24.5 (2.93.5) Linux
Octane Server - Enterprise Edition - 24.5 Linux
