All access not valid for Cinema 4D Plugin?
davidvonbehr
Hi everyone,
I wanted to give the C4D plugin a try (normally I use the modo plugin).
But very strangely I cannot activate the C4D plugin ...
I have an Enterprise license with all access and the authentication dialog says: "You have 1 available Enterprise all access license, which is not valid for the Cinema 4D Plugin."
What? Why? :shock:
Weezer
Because OTOY’s licensing system is weird and overly complex?
Hi davidvonbehr,
probably depends on the version you have installed.
About licenses issues, please write to help at otoy dot com, sharing your Otoy Username, thanks.
ciao
Beppe
