How to work with localDB in lua
Forum for OctaneRender Lua scripting examples, discussion and support.
abzivid
How can one get and work with liveDB from lua scripts?
Seems that octane.importLocalDB is not available.
Aleksandar
here you can find a lua script for finding all materials IDs from LiveDB, and to download the desired material based on ID:
viewtopic.php?f=23&t=54623&hilit=.lua#p278441
I have just tried them with Standalone 2020.2.5, and they seem to work as expected.
ciao
Beppe
abzivid
Hi beppe,
I appreciate the answer and I'll use liveDB at some point.
However, I want to use localDB programmatically.
Could not find API support for the local one.
Aleksandar
Oops, sorry,I have answered at the first question only.
About LocalDB, it is just a path with a series of .orbx files saved in it.
So you can use octane.project.getPreferences to read the NT_LOCAL_APP_PREFS node, and get the LocalDB path with A_LOCALDB_DIR.
If not changed in Preferences, by default it is set to C:\Users\UserName\AppData\Roaming\OctaneRender\localDb.
ciao
Beppe
abzivid
Many thanks. Will try it today.
Pity that getting localDB using API is not more direct and intuitive :(
Aleksandar
Return to “Lua Scripting”
