M1 ARM MacBookAIR and IPR issue. (PR11)
- pixelsmack
As you can see from the attached image, I can not get the IPR to fill its viewer. It's stuck at some set size and it will not alter. Even for extreme camera resolutions with wide aspects. 3:1, etc. For the attached example it's simply a 16:9 aspect camera but the IPR refuses to fill the screen. Other than this, it's been very fast and working well.
If you are working using a HiDPI display mode, you need to enable the option in the plugin options panel to use it and configure the HiDPI scale.
Hope it helps,
Hope it helps,
- Attachments
- 2021-10-18 23_11_31.png (3.29 KiB) Viewed 2644 times
