Out Of Memory
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
jeremyshin
A. Windows 10 Professionnel 21H1
B. 2 X 2080Ti
C. 128 GO
D. Nvidia driver version 472.12
F. OctaneRender plugin version 2020.2.4 R2
G. Cinema 4D R23
I was rendering a 113 frames scene and everything freezed from frame 62. I am unable to start back the render, even from frame one. I have multiple errors with OOM, even if I set OOM at 64 GO for exemple.
I attached Octane log and bug report as zip file.
Any quick help appreciated because I am on en deadline :(
Thanks!
Started logging on 14.10.21 19:46:16
OctaneRender Studio 2020.2.4 (10021600)
CUDA error 2 on device 1: out of memory
CUDA error 2 on device 0: out of memory
-> failed to copy 2D array to device
_BugReport.zip
(141.28 KiB) Downloaded 110 times
snahbah
Try bumping out your out of core to use your RAM as well as your VRAM?
How can we help you? You should have something that's causing it. You may try the latest build and do quick test renders while you deleted/disabled some content and render passes.
Return to “Bug Reports”
