OctaneRender™ for Blender 2021.1.RC3 - 24.4 [TEST]
azen
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Updated to Octane 2021.1.RC3
  • Supported more custom AOV passes(up to 20)
  • Supported more global texture passes(up to 20)
  • Supported Camera Data in Render AOV node tree and Composite node tree
  • Supported Object Data Node in the Octane Composite/Render AOV Node Tree
  • Added the "environment depth" in the Z depth AOV node
  • Added the "shading enabled" and the "highlight backfaces" in the Wireframe AOV node
  • Added the "orbx" extension in the export filename if necessary
  • Added "Quick-Add NodeTree" button in the node editor header for creating a default node tree automatically
  • Added Baking Texture
FIXES SINCE LAST RELEASE
  • Fixed the min/max issues for float inputs
  • Fixed the precision issues for float inputs
  • Fixed Live/Local DB material issue
  • Fixed the issue that the "Quick Add NodeTree" replaces other windows' node trees
  • Fixed the duplicated "Object Data nodes" in the search list
  • Other bug fixes
You can read about new features of OctaneRender™ 2021.1.RC3 here:
viewtopic.php?f=33&t=78516
1. OctaneRender™ Server
Windows
Blender Octane Edition - 24.4 (2.93.4)
Octane Server - Enterprise Edition - 24.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 24.4 (2.93.4) Linux
Octane Server - Enterprise Edition - 24.4 Linux
