It is still not possible to see all the vectron parameters when loading certain osls with many params. Is there any way to easily remedy this?
https://photos.app.goo.gl/AZHnjyffF1RCEN2z5
Vectron UI does not show all parameters
- neonZorglub
Hi Martians,Martians wrote:It is still not possible to see all the vectron parameters when loading certain osls with many params. Is there any way to easily remedy this?
From your screenshot, it seems you are using a desktop scale > 100 %
So I guess there could be a small UI error with some variable types (like integer combo boxes)..
Could you send me a sample of such big osl ?
I'll check and it should be fixed in the next release.
As a work around, you could add some dummy variables at the end of your input variable list, for example
shader myShader(
... your list,
float dummyVar01=0,
float dummyVar02=0,
float dummyVar99=0,
output _sdf c = _SDFDEF)
You will get some warnings of unused variables, but at least you should see and use all your parameters..
- neonZorglub
UPDATE:
This is fixed in 2020.2.5 - 11.15: viewtopic.php?f=80&t=78547
and 2021.1 RC3 - 12.05: viewtopic.php?f=80&t=78548
So awesome, Thanks for fixing that!
