Octane Solaris plugin 2020.2.5.0 - 09-20-21 [OBSOLETE]
BK
Dear Octane community,
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for Solaris V2020.2.5 - for Houdini 18.5.633.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrate completely with Houdini 18.5 Solaris.
What is OctaneRender for Solaris?
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
https://renderman.pixar.com/stories/pixars-usd-pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launch it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
- Changes since 2020.2.5.0 - 09-07-21 [Test]-
  • Fixed VDB Grid mapping UI in RenderGeometry settings node
  • Added support for Volume Ramp
  • Fixed Gradient Ramp node
  • Improved Distant light
-Known Issues-
- Octane Color response is disabled because Hydra buffer expects linear output
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
Enterprise Subscription Downloads
OctaneX PR11 Houdini 18.5.596
2020.2.5.0 Houdini 18.5.633
Studio Subscription Downloads
Demo build Download
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
