Work around for using more than 3 UVs in a mesh?
pixelsmack
I have an exported mesh of an Oil Rig. It was a bake out of 3DSmax from vRay. It contains 6 UV maps. I don't see anyway to non-destructively collapse them. Is there a way in Octane to gain access to all 6?
juanjgon
Nope, sorry. This is a core limitation.
KVNOODLES
pixelsmack wrote:I have an exported mesh of an Oil Rig. It was a bake out of 3DSmax from vRay. It contains 6 UV maps. I don't see anyway to non-destructively collapse them. Is there a way in Octane to gain access to all 6?
Try to separate your mesh in several layers and spread your UVs into them.
mikefrisk
I use different surface names and rename all my UVs into the same map called "UV". Works perfectly for me.
TheMightySpud
The UVMAP Node is indispensable for stuff like this. Set up the LW native 'color' channel with the UV assignment/color texture and use the UVMap Node set to 'get Textures from T channel' (Or whatever it says lol.).
pixym
mikefrisk wrote:I use different surface names and rename all my UVs into the same map called "UV". Works perfectly for me.
Perfect !
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
Return to “Lightwave 3D”
