OctaneRender™ for Blender 2021.1.RC2 - 24.3 [TEST]
azen
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to Blender 2.93.4
  • Supported new Octane proxy node(under the "Node Graph Editor-Octane Advanced Node-Octane Proxy")
  • Supported new OSL nodes
  • Added the legacy "Bake Texture"
  • Supported to use the Blender's classic compositor for both new AOV render group and legacy render passes
FIXES SINCE LAST RELEASE
  • Fixed the color selector issue in the RGB color node
  • Fixed no outputs issue in the Blender's classic compositor
Features of the New Octane Proxy Node
  • The Octane Proxy feature enables users to embed an Octane graph into the Blender's node graph.
  • How to use the "Octane Proxy"
  • How to add an input
  • The attached "OctaneProxySample.blend" shows how to use proxy nodes for material, texture, and geometry.
  • Please notice that this is the first version of the Octane Proxy. It is still BETA. and there are some limitations.
  • The Octane Proxy window is modal, which means you cannot operate in Blender when editing the proxy graph(we may support a non-modal editor in the future)
  • Only 1 output socket is supported(we may support more in the future)
  • Please avoid using the duplicated names for the inputs/outputs
  • Only working for the OctaneServer that is running at the same machine
New OSL Nodes Features
  • Now OSL nodes support min/max limitation
  • Support Enum dropbox
  • Support "Quick-add" feature in OSL nodes
You can read about new features of OctaneRender™ 2021.1.RC2 here:
viewtopic.php?f=33&t=78306
1. OctaneRender™ Server
Windows
Blender Octane Edition - 24.3 (2.93.4)
Octane Server - Enterprise Edition - 24.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 24.3 (2.93.4) Linux
Octane Server - Enterprise Edition - 24.3 Linux
[/list]
(793.91 KiB) Downloaded 244 times
