Hi.
I having problem when testing the latest build OctaneRender™ for Blender 2021.1.RC1 - 24.2 [TEST]
Render settings is default.
The model is a .blend file. I`m using the latest studio driver and rendering with a rtx 3090.
(see video file attached.)
It works fine with OctaneRender™ for Blender 2020.2.4 - 23.10 [STABLE].
Anyone else having the same problem?
/Fredrik
Render bug
C. RAM Capacity (i.e. 6 GB)
- Fredrikvictorhugo
- Attachments
- Desktop 2021.08.23 - 10.52.19.02.mp4
- video showing the problem
- (94.23 MiB) Downloaded 2393 times
- llennoco22
I also have a very similar issue, specular rays stop working at certain camera angles (reflections or transmission disappears). Hard to describe the cause/ how to reproduce. Hiding certain objects can also make the issue disappear or return. (see attached)
- Attachments
- 734a66253075a649d34bc7cdda21b6a0.mp4
- (1.25 MiB) Downloaded 2336 times
- llennoco22
Yes, given that is posted in C4D plugin, im guessing it would suggest it is actually core issue.elsksa wrote:Hi, I did not see the video yet (and not able to play them without downloading them), however, the description of the issue reminds of this forum-post: viewtopic.php?f=86&t=78275 are you both experiencing the same?
- linograndiotoy
Would it be possible for you to share the scene with me?Fredrikvictorhugo wrote:Hi.
/Fredrik
- Fredrikvictorhugo
Hi.
Yes i can share.
When I test the same scene I got some flickering in the plane.
The colour disappears when rotating around the model.
Its not the same issue as the video.
Sent you the link.
/Fredrik
Yes i can share.
Sent you the link.
/Fredrik
- linograndiotoy
Thanks for sharing your scene, Fredrik.
I've tested it in the current internal build and I got no visible issue. I'm using 2 RTX2080 Ti cards by the way, so I wonder if this could be some specific 3090 issue.
I'll check that soon as well.
- Fredrikvictorhugo
Hi. The bug is gone in the latest release 2021.1.RC2 - 24.3 [TEST]
/Fredrik
/Fredrik
