OctaneRender™ for Blender 2021.1.RC1 - 24.2 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to Blender 2.93.2
  • Updated to Octane 2021.1.RC1
  • Supported the new OctaneRender AOV Editor
  • Implemented a new Style Node Graph
Features of the New Style Node Graph
  • Update almost all nodes to the new style
  • Add "Group Socket" to show/collapse the sockets in the category
  • Add "Quick-Add' feature
  • Click the "+" sign to add an Octane default node(if there is one).
  • OR Open a menu with all suitable nodes(if no default node available)
  • Use 'Shift + Click' to always open the menu
  • Quick Move Up/Move Down/Remove buttons for the Octane's movable inputs
  • Implement a new node view panel for the Octane nodes
  • Additional Features:
    • Support multi-level menu
    • Colorize all sockets in the Octane Standalone style
    • Add Octane Link checker
    • Add Octane descriptions for the sockets
    • Reimplement all the Enum sockets
  • Now OctaneBlender will check the link validity once the node graph changes. The invalid link will be marked as Red.
  • All sockets will be colorized as Octane Standalone. Generally, only the link between the same color sockets is valid.
How to use the New Render AOV Feature
  • Create the Render AOV node graph in the "Octane Render AOV Editor"
  • Select the "Render AOV Node Graph" style in the Render Pass Property panel
  • Select the render AOV node tree
  • Switch the "Preview Render Pass" in the active "Render AOVs Output"
    You can read about new features of OctaneRender™ 2021.1.RC1 here:
    viewtopic.php?f=33&t=78125
    1. OctaneRender™ Server
    Windows
    Blender Octane Edition - 24.2 (2.93.2)
    Octane Server - Enterprise Edition - 24.2
    Linux
    Installation:
    $ OctaneServer &
    DOWNLOAD
    Blender Octane Edition - 24.2 (2.93.2) Linux
    Octane Server - Enterprise Edition - 24.2 Linux
