i've been working on this project for a while and Octane has been working as normal.
yesterday some glass and water materials suddenly started rendering solid black and some other metals are rendering with completely different scene materials.
if i move the camera it renders fine again but i need specific views which are refusing to render correctly.
i thought it might be a corrupt file but i've now tried numerous previously saved files and the issue is still there.
really don't understand why this is happening and i really need to get this working as i have deadlines approaching.
other things i've tried:
reinstalling the modo plugin
deleting MODO prefs
it's worth repeating, the scene renders fine at some angles but refuses to render correctly depending on where the camera is. and it's random too, so navigating to the same spot doesn't necessarily mean the same behaviour.
also worth repeating everything was working fine til yesterday and scenes i haven't opened in weeks that previously worked fine (including the views i need) are now refusing to render.
any ideas pls?
weird glitch rendering materials
I'm going to assume you are using one of the 2021.1 builds. These are still considered experimental. You should not be using them for real work yet.
The specular / camera issue you mention will be fixed in a future build
viewtopic.php?p=403176#p403176
viewtopic.php?p=403194#p403194
I have also bugged Paul with an issue related to metals, but it would have been good for you to get a scene to him as well, so we are sure it's the same problem.
thanks funk - i should keep an eye on the experimental threads.funk wrote:I'm going to assume you are using one of the 2021.1 builds. These are still considered experimental. You should not be using them for real work yet.
yes, i wanted to use one of the new AOV features so installed the experimental version. shame there's no easy way to just switch versions (or maybe there is?).
unfortunately right now i have a lot on so am reluctant to reinstall a version i know is not working in case i wake the sleeping dog
if i find some time though i will post re the metal issue, but hopefully it's connected to these other specular issues and it does seem that way
