OctaneRender 2020.2 for Houdini Production build 2020.2.5.0
juanjgon
This is a production release of the OctaneRender™ 2020.2 for Houdini™ plugin compiled with the Octane 2020.2.5 core. This 2020.2.5.0 release is available for the latest Houdini production builds on Windows x64, Linux gcc6.3.1 and MacOS 10.12 (CUDA).
Houdini production builds supported by this release: 17.5.460, 18.0.597, 18.5.563, 18.5.596, 18.5.633 and 18.5.672
Make sure to use an NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
New features
To learn more about the new features and improvements of OctaneRender 2020.2, please check out the 2020.2 release post, but this is a brief list of the main new features that have been added.
  • Improved RTX performance.
  • Fast Spectral Nested Dielectrics.
  • Denoiser support for the new NVIDIA Ampere devices.
  • ACEScg and filmic processing. New color options available in the Octane ROP node.
  • OpenColorIO Management, Display and Export (OCIO profile). Configured from the "OCIO" environment variable.
  • OpenColorIOColor graph nodes. Look, Profile and View nodes
  • Integrated multi-scatter from volumes or surfaces. Available in the Octane OBJ spare parameters.
  • User generated compositor AOV passes for combining render and light passes in full a compositor node graph.
  • Null material.
  • Spotlight texture.
  • New ray type, texture composite and channel tools shader nodes.
  • Improved color correction node.
  • New chaos texture node.
Release 2020.2.5.0 Enterprise subscription license
https://render.otoy.com/customerdownloa ... rprise.zip
Release 2020.2.5.0 Studio subscription license
https://render.otoy.com/customerdownloa ... studio.zip
Release 2020.2.5.0 Demo license
https://render.otoy.com/plugindownloads ... 4_demo.zip
https://render.otoy.com/plugindownloads ... x_demo.zip
https://render.otoy.com/plugindownloads ... X_demo.zip
Release 2020.2.5.0 for H18.5.672 All OSs
https://render.otoy.com/plugindownloads ... 2_demo.zip
Standalone 2020.2.5 version for the network rendering nodes
viewtopic.php?f=15&t=78208
Release Notes
RELEASE 2020.2.5.0
* PLUGIN FEATURES AND FIXES:
- Fixed a problem with the license authentication from hython.
* OCTANE FEATURES AND BUGS FIXED:
- Fixed issue causing some textures to be interpreted differently when using out-of-core.
- Fixed application crash during startup.
- Fixed SSS pass which was causing a difference between the main pass and the denoiser output passes.
- Fixed issue with scenes with render layers and alpha channel enabled causing incorrect denoiser output.
- Fixed universal camera diopter rotation to be interpreted as degrees instead of 0-1.
- Fixed broken rotation for 2D transforms.
- Fixed an issue causing a freeze when disabling RTX while tone-mapping was happening.
- Fixed issue causing some dialogs to display in plugins that use the silent activation mode.
Happy rendering,
Your OTOY Team
davidyannick_1
Maybe I have a problem with my setup or this version does not support Houdini 18.5.672 ?
galleon27
davidyannick_1 wrote:Maybe I have a problem with my setup or this version does not support Houdini 18.5.672 ?
Houdini production builds supported by this release: 17.5.460, 18.0.597, 18.5.563, 18.5.596 and 18.5.633
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
davidyannick_1
sorry for the question I didn't pay attention ...
juanjgon
Yes, the Octane plugin and Houdini versions usually should match. I'll try to release a new 2020.2 plugin build for the latest Houdini production build early next week.
davidyannick_1
juanjgon wrote:Yes, the Octane plugin and Houdini versions usually should match. I'll try to release a new 2020.2 plugin build for the latest Houdini production build early next week.
ok gonna wait thanks
juanjgon
I've updated this post including a proper plugin build for H18.5.672, including all the licenses and OS types.
davidyannick_1
juanjgon wrote:I've updated this post including a proper plugin build for H18.5.672, including all the licenses and OS types.
juanjgon
Sorry, there was a problem with the H18.5.672 build. It was compiled against the wrong Octane core version. I'll upload it again ASAP.
Thanks for your patience,
davidyannick_1
juanjgon wrote:Sorry, there was a problem with the H18.5.672 build. It was compiled against the wrong Octane core version. I'll upload it again ASAP.
