My c4d can load any plugins except for the Octane :cry:
bigfwang
:cry:
Windows 10
C4D Version: R23 &S24
Graphics card : NVIDIA RTX 3090
OC :Latest version
Once everything was normal, but recently I opened the software,all plugins are fine but the Octane,just can find it in the software...No matter i reinstall the octane plugin or cinema 4D ,problem can't be solved.
Is there only a way to reinstall the system? :cry: :cry: :cry:
Is your C4d version numbers matching the minimum requirements?
bigfwang
aoktar wrote:Is your C4d version numbers matching the minimum requirements?
Thank you very much, aoktar
emmmm..Please teach me how to check this the minimum requirements
Although my C4D version numbers is not the latest, it should be close to the latest version. I think there should be no problem
You can read install notes from this release topic. Plugin will not be loaded if your C4d is older than this versions.
viewtopic.php?f=85&t=77898
bigfwang
aoktar wrote:You can read install notes from this release topic. Plugin will not be loaded if your C4d is older than this versions.
I double-checked the software version and confirmed that they all meet the minimum requirements
Please try to repaire the Microsoft Visual Studio (Visual C++) 2015/2017/2019 installation, in general solves the issue.
https://aka.ms/vs/16/release/vc_redist.x64.exe
ciao Beppe
