Octane off sync with LW image sequence.
Sub forum for bug reports
xevious2501
Octane off sync with LW image sequence. multiple LW versions.
This has occurred before,
Octane will be a frame offset from lw's image sequence.
This happens both in 24fps and 23.976
crazy enough, when the actual anim is sync with the footage LW will show one frame and octane will be another but in sync with the object.
understandably this is a huge issue when trying to get work done.
Any remedy? :?
promity
can you post a small version of your scene with this problem?
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
juanjgon
Yes, a repro scene could help. I think that I've not seen this problem before. Are you working with floating frame numbers or something like that?
Return to “Bug Reports”
