Hi everyone,
I am working on an animation right now, where moving lights should speed up and turn into moving light streaks. I searched the forum already, but just found tips, that say you should not use lights but objects with emission. That I already habe because the setup is a mograph setup with objects moving along a spline.
So the scene is a bridge with moving light. As you can see in the clips, it works pretty good on the road as expected, but on the piers it causes issues. What is strange because on one pier it kind of works but not on the other one. But they are exactly the same setup, copied and just moved it. First I thought its maybe the camera angle and the distance, but even if I move the camera it stays like this.
I would be glad to solve this problem with your help. Thanks everybody!
Lights and Motion Blur
- Attachments
- mb_test_mb.mp4
- and here with motion blur activated
- (2.39 MiB) Downloaded 617 times
- mb_test.mp4
- this is the scene without motion blur
- (2.27 MiB) Downloaded 616 times
please go to render settings/OctaneRender/Main tab, and increase the Time Sampling per frame value, and check the axes of the second pier.
ciao Beppe
ciao Beppe
