problem with lighting
Xenoglossia
Hello. So I render a scene in Octane and I can't seem to reach a value of 1 for bright areas of the image. In Cycles it renders fine, but in Octane no matter how bright I make the light source (area light) it never reaches a value of 1 for brightness in the image. I enabled OctaneCameraImager, enabled Neutral Response, tried different response types including sRGB and gamma 2.2 and still no fix. I tried changing exposure, didnt fix it. Thanks
sorry, the issue is not clear.
Please post some screenshot of the result you are having, and the result you want, and also of Kernel, Camera Imager and Area Light settings, thanks.
ciao Beppe
Are you using preset command for creating an Octane arealight?
