I had to reinstall my TitanX (before I deinstalled everything via DDU in safe mode) and Octane doesn´t render anymore. TitanX driver is up to date.
C4D R19, Octane 3.08.2-R2.1
I can see TitanX under "devices" and it´s checked but when I want to render it says "Render Failure!!! Check console window and octane log window.".
My slower GTX 780Ti gives me Error: (Code 43) in Windows 10 device manager and its resolution is reduced to 800x600 (cant set it back anymore), that´s why I had to delete all drivers with DDU und then reinstall the TitanX again - it happened after an automatic Windows update. I disabled the 780Ti in the windows device manager for now. Issue still exist.
No way to render.
Any ideas?
It drives me crazy... and leaves me clueless.
Octane log says:
OctaneRender 3.08.2 (3080200)
CUDA error 999 on device 0: unknown error
-> failed to link to cubin
device 0: failed to compile OSL code:
error : Undefined reference to 'cuGeo' in 'snippets_internal'
error : Undefined reference to 'cuParams' in 'snippets_internal'
error : Undefined reference to 'TRANSFER_XYZ' in 'snippets_internal'
error : Undefined reference to 'cuXyzToRgbMatrix' in 'snippets_internal'
error : Undefined reference to 'CYAN' in 'snippets_internal'
error : Undefined reference to 'BLUE' in 'snippets_internal'
error : Undefined reference to 'GREEN' in 'snippets_internal'
error : Undefined reference to 'MAGENTA' in 'snippets_internal'
error : Undefined reference to 'RED' in 'snippets_internal'
error : Undefined reference to 'YELLOW' in 'snippets_internal'
error : Undefined reference to 'cu_cam' in 'snippets_internal'
error : Undefined reference to 'cuQueues' in ' '
device 0: failed to compile module 1
error : Undefined reference to 'cuQueues' in 'cuda_texturenode'
error : Undefined reference to 'YELLOW' in ' '
error : Undefined reference to 'cu_cam' in ' '
error : Undefined reference to 'cuGeo' in 'cuda_texturenode'
error : Undefined reference to 'cuParams' in 'cuda_texturenode'
error : Undefined reference to 'TRANSFER_XYZ' in 'cuda_texturenode'
error : Undefined reference to 'cuXyzToRgbMatrix' in 'cuda_texturenode'
error : Undefined reference to 'CYAN' in 'cuda_texturenode'
error : Undefined reference to 'BLUE' in 'cuda_texturenode'
error : Undefined reference to 'GREEN' in 'cuda_texturenode'
error : Undefined reference to 'MAGENTA' in 'cuda_texturenode'
error : Undefined reference to 'RED' in 'cuda_texturenode'
error : Undefined reference to 'YELLOW' in 'cuda_texturenode'
error : Undefined reference to 'cu_cam' in 'cuda_texturenode'
error : Undefined reference to 'GREEN' in ' '
error : Undefined reference to 'MAGENTA' in ' '
error : Undefined reference to 'RED' in ' '
error : Undefined reference to 'cuGeo' in ''
error : Undefined reference to 'cuParams' in ''
error : Undefined reference to 'TRANSFER_XYZ' in ' '
error : Undefined reference to 'cuXyzToRgbMatrix' in ' '
error : Undefined reference to 'CYAN' in ' '
error : Undefined reference to 'BLUE' in ' '
device 0: failed to compile module 0
Tried to access null node
Tried to access pin via an invalid ID P_MESH (111)
Tried to access null node pin
error : Undefined reference to 'cuGeo' in ' '
error : Undefined reference to 'cuParams' in ' '
could not pick materials, because the geometry has changed and rendering is paused
