OctaneRender™ for Blender 2021.1.XB3 - 24.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to Blender 2.93.1
  • Upgraded to Octane 2021.1.XB3
  • Supported motion blur for the imported Alembics
  • Added "Material Override" option in the "View Layer" panel
FIXES SINCE LAST RELEASE
  • Fixed render updating issue when the mesh is empty
  • Fixed memory leak in creating mesh data
  • Fixed library-link object's transform updating issue
  • Fixed Composite Material link issue
You can read about new features of OctaneRender™ 2021.1.XB3 here:
viewtopic.php?f=33&t=78040
1. OctaneRender™ Server
Windows
Blender Octane Edition - 24.1 (2.93.1)
Octane Server - Enterprise Edition - 24.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 24.1 (2.93.1) Linux
Octane Server - Enterprise Edition - 24.1 Linux
