Why does "random color" not work the way it should?
nigromontanus
Hello. As you can see on the image, I tried to create a array with random colors. I did it exactly like the example in the manual. (It's one array and two independent objects.) But I does not work, instead I always get the same color. Why? I simply don't understand it and it slowly drives me mad.
Here is the page from the manual.
https://docs.otoy.com/BlenderH/BlenderP ... exture.htm
nigromontanus
It seems that the Image Tag didn't work. So here is the Link itself.
https://imgbb.com/Ltg81BK
nigromontanus
As you guys are obviously totally excited and waiting for a update, here it is: I did a simple point scattering with Blenders geometry nodes, and here the "random rgb" node works perfectly. So what's the (or just my) problem with arrays and different independent objects?
https://ibb.co/gtbc78f
