Adding a glossy material in 23.10 closes Blender.
This also happens when adding a spot light and enabling nodes for that spot light. (would be a good place for the volumetric spotlight)
But the post was mostly for the glossy material bug.
[23.10] Glossy material bug.
C. RAM Capacity (i.e. 6 GB)
- linograndiotoy
Not sure I get what's the issue you are talking about. You can consider this an hot fix. All you need to do is to download the current installer again and re-install it. Why would you need a different version?roentgen wrote:Why will not you increase a version number?
Honestly stability issue like this wastes of my time.
I would say sorry for advance if you are not a developer.linograndiotoy wrote:Not sure I get what's the issue you are talking about. You can consider this an hot fix. All you need to do is to download the current installer again and re-install it. Why would you need a different version?roentgen wrote:Why will not you increase a version number?
Why would I need a different version(number)? I have never considered that but, you know, I use the version number to;
1. help to identify an issue as an issue that people talk about here if there are some similar issues.
2. report to developers. I think it's better that information to produce the issue.
3. notice that the new release's came up in the download page or headline.
To developers:
When you have a hot fix, will you consider to put the build number down the release?
I missed a hot fix you said while I checked the download page every day. This is my fault.
But just I would love to know you have a hot fix WITHOUT REMEMBER THE DATETIME OF DOWNLOADED. Usually I can do this by checking short digits, the version/build number.
Please, consider increasing version or giving a build number clearly, please.
- linograndiotoy
We normally always do it.Please, consider increasing version or giving a build number clearly, please.
This one has been a very special case, since the crash was identified basically the same day we released the "bugged" version.
Unfortunately I don't agree that immediately.
A past release, 23.1 or around, we met to confuse at the same kind of situation.
viewtopic.php?f=114&t=77082
That time I wrote "23.1" on a report but there was newer "23.1" than "23.1" I have.
I did re-download and re-install as you said, however the issue still reproduced. I confused that the fix was incomplete or it wasn't same issue or re-installing was failed.
There was nothing that's sure thing for me. No way to make sure whether re-install's done or even a download link was correct.
If you give it a version, build or patch number, you could identify the issue, I could notice the fix and make sure that re-install was succeeded.
