OctaneRender™ for Blender 2021.1.XB1 - 24.0 [TEST]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to Octane 2021.1.XB1
    • Upgraded to OCIO v2
    • Added OCIO Color Context Node
    • Added "Color space" and IES file mode for image nodes
  • Added new materials, textures, and projections
    • Added "Clipping Material"
    • Added "Binary Math Operation"
    • Added "Unary Math Operation"
    • Added "Capture to Custom AOV"
    • Added "Normal"
    • Added "Position"
    • Added "Random Map"
    • Added "Range"
    • Added "Ray Direction"
    • Added "Relative Distance"
    • Added "Sample Position"
    • Added "Surface Tangent Dpdu"
    • Added " Surface Tangent Dpdv "
    • Added "UV Coordinate"
    • Added "Z Depth"
    • Added "Float3 to Color"
    • Added "Float to Greyscale"
    • Added "Floats to Color"
    • Added "Color to UVW Projection"
    • Added "Distorted Mesh Projection"
    • Added "Mat Cap Projection"
    • Added "Sample Pos to UV Projection"
  • Added new AOV output nodes
    • Added "Clamp AOV Output"
    • Added "Color Correction AOV Output"
    • Added "Light Mixing AOV Output"
    • Added "Map Range AOV Output"
  • Other new features
    • Added BSDF model: GGX(energy preserving)
    • Added new pins to "Scatter on Surface"
    • Added "Read VDB"
    • Added Mesh Volume SDF nodes(invisible due to engine crash in the current version)
    • Added "White light spectrum" option
    • Added "use old color pipeline" option
KNOWN ISSUES
  • The new AOV Group features will come in the next version
You can read about new features of OctaneRender™ 2021.1.XB1 here:
viewtopic.php?f=33&t=77764
1. OctaneRender™ Server
Windows
Blender Octane Edition - 24.0 (2.93)
Octane Server - Enterprise Edition - 24.0
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 24.0 (2.93) Linux
Octane Server - Enterprise Edition - 24.0 Linux
