2D surface Position noise on 3D object
Houdini Integrated Plugin
HBHATTI
I have a sphere with multiple scattered points on it, tried to use the attribnoise function applied on P, but the points are as expected transforming away from the surface; is there a way to apply 2D surface position vector without affecting the radius of the scattered points? Thanks
**I have tried using v@P = v@P - rest; ie using the rest position vector of the scattered points, but it is not giving correct results
vector rest = v@rest;
v@P = v@P - rest;
juanjgon
Are you talking about the Octane native scattering feature? Can you please share your scene to take a look at it here?
HBHATTI
Ahh sorry, I just meant the standard Houdini scattering, not octane, am attaching file; I discarded the vex attempt because I think I need a fresh start; I just need the noise to stick to the surface
2D noise.zip
(24.31 KiB) Downloaded 135 times
juanjgon
You could work with the VEX noise functions, as you can see in the attached scene.
2D noise_juanjo.zip
(17.63 KiB) Downloaded 138 times
HBHATTI
Ahh ok, thank you kind sir, appreciate it.
Return to “Houdini”
