ORBX export always fails to work
zlskpotti
ORBX export always fails to work. When I click export, it crashes, crashes, and crashes. I tested different versions, but none of them worked. Even if there is only one BOX in the scene.
test.blend
(1.02 MiB) Downloaded 183 times
zlskpotti
This is the record of the crash
test.crash.txt
(42.46 KiB) Downloaded 177 times
linograndiotoy
You need a camera to be present in the scene to export an ORBX (but also to just have Octane preview/render work). Assigning a material could be important as well.
Blender shouldn't crash by the way (that's something we need to fix), but the ORBX export works fine as long as you
test.orbx
(179.73 KiB) Downloaded 171 times
Return to “Blender”
