Solaris Integration Unification
Hydra Solaris
HBHATTI
I think it is ridiculous to have two different octane programs installed (if that's how it works?) with two different functionalities on the same Houdini Program???!!! It should be a single unified rendering system solution that works in the standard Houdini Mode and Solaris mode. I will have to wait until this is more refined but I also want to start learning USD and Solaris basics as a beginner. What are developer thoughts, timelines...etc
BK
HBHATTI wrote:I think it is ridiculous to have two different octane programs installed (if that's how it works?) with two different functionalities on the same Houdini Program???!!! It should be a single unified rendering system solution that works in the standard Houdini Mode and Solaris mode. I will have to wait until this is more refined but I also want to start learning USD and Solaris basics as a beginner. What are developer thoughts, timelines...etc
Hi Bhatti,
Thank you for your feedback.
OctaneSolaris plugin build is already unified with our Octane for Houdini main plugin based on Houdini v18.5.532.
The current OctaneSolaris workflow is to build a custom Render Target via the material library node.
We are planning to add Octane UIs one by one in the next few releases.
cheers
Kind Regards
bk3d
HBHATTI
Ok appreciate your kind response, I am really looking forward to project maturity :)
heimlich
are you aware that there is the MAIN plugin OctaneRender 2020.2 for Houdini Production build 2020.2.3.1
which is NOT what the solaris build is... your solaris build from the 27th is still 2020.2.3.0.
The main plugin had a bunch of important crash fixes. So I am not quite sure how this is unified...
Also, the latest Houdini Production build is 18.5.563.
Return to “Hydra Solaris”
