Smoothing not working
twistedpancreas
Hi there new user here using Win10, Blender 2.92 with Octane and following this tutorial where he talks about smoothing https://youtu.be/LyvoLHzNdks?t=887
But unfortunately smoothing doesn't work for me even though it's selected and has edge loops.
Am I missing anything?
Thanks in advance.
twistedpancreas
even weirder is that when I removed the edge loops in the cylinder the material worked, but then when i made a new cylinder with the same material it didn't work again. Any ideas?
protovu
sorry if a dumb question, but did you right click on the cylinder and select "shade smooth"?
twistedpancreas
Hmm I thought right clicking > Shade Smooth only worked in Cycles not in Octane?
But I tried it and it only works after I save the file and re open it again.
Weird.
Thanks for your help.
linograndiotoy
As you use Shade Smooth on a mesh you just need to hit Tab twice to enter and exit Edit Mode. That will update the cache.
By the way, we internally fixed a issue with Smoothing angle, and a new build will be available soon.
twistedpancreas
Thanks linograndiotoy,
that's a much better way of doing it. Could that be added in the manual for the Blender Addon? I'm sure others are running into that same issue.
linograndiotoy
The docs really need way more than that! :D
Return to “Blender”
