Hi guys,
I am a relatively new UE user, I was wondering if it is possible to get octane materials made in Cinema4d or a cinema4d scene with octane materials loaded in Unreal.
Would orbx file work ?
Cinema4d Octane Materials to UE
Moderator: ChrisHekman
- ChrisHekman
Yes, there are two ways at the moment.
You can export your cinema4d scene to orbx.
Then you can import the ORBX as a proxy into the scene. This proxy can then be placed into an unreal scene as a sigle entity.
Or you can import the ORBX. The plugin will then attempt to convert the ORBX scene to unreal assets and a level.
The octane materials then get converted to "octane override materials" in Unreal.
This second process is not a 100%.
This second option can also approximate the materials in the ORBX to unreal materials.
- dingyuxiang
What services do I need to subscribe to install ? I want Inport C4D Octane Materials to UE4.
- ChrisHekman
You would need a C4D license. Unreal has a free tier you can use, but also a licensed tier.dingyuxiang wrote:What services do I need to subscribe to install ? I want Inport C4D Octane Materials to UE4.
- Respecognize
ChrisHekman wrote:Yes, there are two ways at the moment.
After placing the orbx proxy in your scene, how do you start render? Is there a specific place you have to put your scene or any settings after you put the proxy in your world? And you mean just drag and drop into the level right?
- ChrisHekman
You will need to create a rendertargetactor (you can select the option from the octane dropdown menu, or via the normal way of creating actors)Respecognize wrote:ChrisHekman wrote:Yes, there are two ways at the moment.
Then select the rendertargetactor, and press the render button in the details view
