OctaneRender™ for Blender 2020.2.3 - 23.6 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Supported to use the Octane images for painting texture
  • Supported to refresh viewport rendering dynamically when painting texture
  • Supported to use Blender collection in the Octane Object Data Node
  • Supported to use of the collection for Octane Scatter Tool
  • Setup Octane tags in the Octane Output panel by default
  • Added nested dielectrics option in kernel
FIXES SINCE LAST RELEASE
  • Released the Octane GPU RAM when clicking "Clear Cache"
  • Set root thickness value for hair as 0.0001 by default
  • Rename "Auto" mesh type to "Scatter/Movable" since it does not handle "reshapable" cases
  • Fixed a few update issues for the "Auto" mesh type
  • Fixed the crash issue when using the material layer
  • Fixed a few group input issues
You can read about new features of OctaneRender™ 2020.2.3 here:
viewtopic.php?f=24&t=77414
1. OctaneRender™ Server
Windows
Blender Octane Edition - 23.6 (2.92)
Octane Server - Enterprise Edition - 23.6
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 23.6 (2.92) Linux
Octane Server - Enterprise Edition - 23.6 Linux
OSX
DOWNLOAD
Blender Octane Edition - 23.6 (2.92) OSX
Octane Server - Enterprise Edition - 23.6 OSX
