Sculptron 1.1 crashing on opening file with imported abc
Discussion forum for Sculptron
pegot
I tried with numerous abc files, even ones created in and exported directly from Sculptron itself. Sculptron imports the abc files fine but after saving the scene with the imported alembic, Sculptron crashes trying to open the saved file.
I can upload files if necessary but should be reproducible just by adding a Torid starter object, exporting it as alembic, creating a new blank Sculptron file and saving the file after importing in the Torid abc. When trying to open this newly saved file with the imported abc, Sculptron will crash.
At least that is what is consistently happening on my system.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
linograndiotoy
Checked and verified.
We'll release the hotfix as soon as possible! Thanks again for your report!
linograndiotoy
Hotfix! Please load Sculptron.exe from the following link and replace it in your Sculptron 1.1 install folder:
Updated Sculptron.exe
pegot
linograndiotoy wrote:Hotfix! Please load Sculptron.exe from the following link and replace it in your Sculptron 1.1 install folder:
Hey Lino, there was a problem trying to install the Sculptron Hot Fix exe. "...code execution cannot proceed because mimalloc.dll was not found." See attached screen shot.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
linograndiotoy
Did you copy the exe in the Sculptron 1.1 installation folder?
pegot
No I didn’t I thought it was an installer. But that makes sense to just drop it in the program directory since it’s a hot fix. Thanks for clarifying.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
linograndiotoy
Sure!
Return to “Sculptron”
