Render Region - Broken (?)
batesey
Paul,
Has there been a particular change to the render region tool in OctaneRender_for_Modo13-14_2020_2_3_171_ENTERPRISE that would stop it from working?
I simply can not get a render region to work anymore. I updated from OctaneRender_for_Modo_2020_1_5_163_ENTERPRISE last week and since then, no render region.
I've tried downgrading to 169, but that only randomly worked. 170 and now 171 don't work for me at all. Working on large interior scenes is a pain without render region working
Has anyone else had this issue? Any suggestions?
Toby
batesey
Paul,
I think I found out what the issue was with my render region problem...can you please confirm if this is normal or abnormal behavior.
When Cryptomatte is enabled, the render region will not work.
Toby
batesey wrote:Paul,
Toby
I just tried this in Octane Standalone, and it does indeed appear to be an issue. May I suggest you report this problem on the Octane Standalone 2020.2.3 release thread.
Return to “Foundry Modo”
