It seems that packed geo instancing always works like its in Full Scene Reload, as in when Rendering mode is set to Update scene, it still needs to process in every single frame.
The usual way of instancing, with instance sop, works fine. I have attached a quick video showing the speed between the two.
Packed geo instancing
C. RAM Capacity (i.e. 6 GB)
- Attachments
- instance_test.mp4
- (3.39 MiB) Downloaded 1339 times
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
Oh ok. Good to know. Guess i'll have to switch. Thanks for the info.juanjgon wrote:Yes, sorry. This is a known limitation. The packed geo instancing forces a full scene reload. If this has a big impact in your scene rendering time, you should switch to conventional instancing.
Cheers.
