Octane Solaris plug-in 2020.2.3.0 - 05-06-21[OBSOLETE]
BK
Dear Octane community,
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for Solaris V2020.2.3 - for Houdini 18.5.532.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrate completely with Houdini 18.5 Solaris.
What is OctaneRender for Solaris?
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
https://renderman.pixar.com/stories/pixars-usd-pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launch it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
- Changes since 2020.2.1.2 - 04-08 Test-
  • Implemented Distant light and Point light
  • Implemented Octane Daylights, Planetary and default Environment color in the render setting.
    Now, the workflow requires Render Setting node as the BG is default to none(no Lights in the scene)
  • Support Refractions for USD Preview Material
  • Fixed VDB Crash. Please apply Octane Volume medium if the VDB sequences does not load when scrubing the timeline.
  • Other bug fixes
-Known Issues-
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
- we are still experiencing issues with Octane nodes working correctly due to what appears to be issued with the version of USD that Houdini is built with.
Enterprise Subscription Downloads
2020.2.1.3 Houdini 18.5.532
OctaneX PR11 Houdini 18.5.532
Studio Subscription Downloads
Demo build Download
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
Tugpsx
Very nice. keeping an eye on this project.
rohandalvi
This is good progress. All the lights work now.
But I can’t seem to get DOF to work. Also, after a while the viewport just froze, nothing would update, as if the image that’s as rendered was just stuck on the viewport. switching back to standard Houdini OpenGL viewport was fine but the octane viewport was just stuck.
jandress
Any ETA on a Linux release?
BK
Tugpsx wrote:Very nice. keeping an eye on this project.
Thank you Tugpsx!!
Kind Regards
bk3d
BK
rohandalvi wrote:This is good progress. All the lights work now.
Hi Rohan,
Thank you so much for running a test :)
Unfortunately, we are yet to implement the DOF features. It would be added in the coming releases.
cheers
Kind Regards
bk3d
BK
jandress wrote:Any ETA on a Linux release?
Hi Jandress,
Thank you.. sorry! we do not have any ETA on a Linux release yet.
We will check with seniors and will get back to you ASAP!
cheers
Kind Regards
bk3d
