Instancing hierachy not working?
tombosschaert
Is it a known issue that Octane does not render the hierarchy of an instanced item?
You know, when 'instance hierarchy' is on in the Lw instance panel? At least with me, it doesn't.
juanjgon
Hmm, I'm not sure if this feature works in Octane. I've not seen anything about hierarchies in the LightWave SDK instancing API, but perhaps it is handled automatically. No one is able to render this kind of instancing?
Lewis
Mine works (always has), I had many cars and trees which have hierarchy (several layers parented to main layer) in my scenes.
So must be something specific in your workflow/setup so we need more info to see what could it be.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
juanjgon
Yes please, if you can share an example scene (as simple as possible) with this issue I could take a look at it here.
Rainbow-3D
maybe because you moved the pivot point? It happened to me only one time because usually I don't move the pivot, so I didn't care and I didn't lost more time, simply I resolved copyng the object, but maybe this is your problem. Need some tests.
Win 7 x64 | Asus P8P67-M - i72600K | 16 GB RAM | 1 x nVidia RTX 2800
Win 11 | i7 13700K | 64 GB RAM | 1 x nVidia RTX 4090
promity
Most likely the error lies in the render settings - you need to disable Instance LW clones and Instance -(name) Nulls in Octane Render Target tab.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
Return to “Lightwave 3D”
