Crsh with Multthreaded scene extraction
tombosschaert
I have a LW crash with the latest version of the plugin when opening IPR. The crash disappears when I disable the new 'multithread scene extraction'.
I'll gladly send a packaged scene. It's pretty huge though. Where should I send it to?
juanjgon
You are working with the 2020.2.3.1 plugin build, right? It has several fixes related to this feature.
You can send me the link to download the scene by pm ...
tombosschaert
It is the latest version, but I am using 2019, because 2020 crashes with Octane material conversion, and it rotates my oriented instances 90 degrees.
I have also tested 2020, but that crashed as well.
I will send the scene through PM.
scooternva
FYI I have found that if NVLink is disabled multi-threaded scene extraction works. But if NVLink is enabled, kaboom.
Octane 2020.2.3.1 | LightWave 2019.1.5 (3134) | Win10 Pro 19041.1052 | 2 x Gigabyte AORUS RTX 2080 Ti Xtreme w/NVLink | Gigabyte AORUS Xtreme X399 | AMD Ryzen 2950X | 64 GB RAM | SSDs: Samsung 970 PRO 512 GB + Seagate FireCuda 510 2 TB | blog.gammans.zone
juanjgon
scooternva wrote:FYI I have found that if NVLink is disabled multi-threaded scene extraction works. But if NVLink is enabled, kaboom.
Hmm, this makes no sense. The nvlink is a render option that has nothing to do with the scene extraction. It is something really weird. In any case if you have a scene that crashes at the extraction time it could be great to have it here to reproduce the problem.
Return to “Lightwave 3D”
