Hello,
Is there way that get octane nodes to use UVs more than 4 on blender-plugin?
My model have 10 UVs when joint to one for animation but UVW Projection shows only up to 3.
(As I directly put a huge number than 3 fingers, it seems as if the node's capable for it but, unfortunately the node looks like be not able to understand number greater than 3)
regards,
Why can't UVW Projection node refer only UVs up to 3
- linograndiotoy
No, you're limited to 4 UVs per single layer mesh. If you need more you should use UDIMs.roentgen wrote:Hello,
regards,
