OctaneRender 2020.2 LightWave Production build 2020.2.3.1
juanjgon
This is an production release of the OctaneRender™ 2020.2 for LightWave™ plugin version 2020.2.3.1, available for LightWave 11.6, 2015.3, 2018.0, 2019.0/2019.1 and 2020.0 Windows x64 and MacOS (CUDA). This build has been compiled using the Octane 2020.2.3 core.
Make sure to use an NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
New features
To learn more about the new features and improvements of OctaneRender 2020.2, please check out the 2020.2 release post, but this is a brief list of the main new features that have been added.
FEATURES AVAILABLE IN THE LIGHTWAVE PLUGIN:
  • Improved RTX performance.
  • Fast Spectral Nested Dielectrics.
  • Denoiser support for the new NVIDIA Ampere devices.
  • New chaos texture node.
  • Improved color correction node.
FEATURES STILL IN DEVELOPMENT:
  • ACEScg and filmic processing. New color options available in the Octane ROP node.
  • OpenColorIO Management, Display and Export (OCIO profile). Configured from the "OCIO" environment variable.
  • OpenColorIOColor graph nodes. Look, Profile and View nodes
  • Integrated multi-scatter from volumes or surfaces. Available in the Octane OBJ spare parameters.
  • User generated compositor AOV passes for combining render and light passes in full a compositor node graph.
  • Null material.
  • Spotlight texture.
  • New ray type, texture composite and channel tools shader nodes.
Release 2020.2.3.1 Enterprise subscription license
https://render.otoy.com/customerdownloa ... rprise.zip
Release 2020.2.3.1 Studio subscription license
https://render.otoy.com/customerdownloa ... studio.zip
Release 2020.2.3.1 Demo version
https://render.otoy.com/plugindownloads ... 4_demo.zip
https://render.otoy.com/plugindownloads ... X_demo.zip
Standalone 2020.2.3 version for the network rendering nodes
viewtopic.php?f=24&t=77414
Release Notes
RELEASE 2020.2.3.1
* PLUGIN FEATURES AND FIXES:
- Fixed a problem with the gradient and ramp nodes.
- Fixed a problem with the FiberFX objects rendering.
- Fixed a crash in the multi-thread scene extraction feature in LW2015/2018/2019
RELEASE 2020.2.3.0
- Multi-thread scene extraction. New option in the plugin options panel to enable/disable this feature. This feature is limited to 64 cores, or to a single CPU in dual-CPU systems with more than 64 cores. The F9/F10 preview window will be frozen while processing the scene extraction.
- Fixed a problem with the chaos texture transformation parameters.
- Fixed a crash while working with objects whose name starts with "("
* OCTANE FEATURES AND BUGS FIXED:
- Brought back the dialog that allows retrying activation when the connection with OctaneLive has failed.
- Fixed bug causing moving instances to disappear when subframe start would be set to 100% in the animation settings.
- Fixed crash when an OSL shader has two outputs.
- Fixed crash when an OSL shader has a struct as input parameter.
- Fixed render failure when rendering a preview of a toon material.
- Fixed render failure when texture displacement is used on a mesh with no UV coordinates and RTX is enabled.
- Fixed AI denoiser on macOS by updating cuDNN to version 7.6.5.
- Fixed volumetric spot light cutting out geometry with a material priority less than 0. This is because the volumetric spot light had a default priority of 0, so if the user tries to set the scene geometry with less than 0 priority, they will be cut out.
- Fixed rendering of fake shadows of nested dielectrics that have SSS.
- Fixed missing attenuation if a toon material is indirectly visible, e.g. behind some tinted glass.
- Fixed material opacity not using the correct opacity when using mix material inside a layered material node.
- Fixed incorrect reset of material layers if a mix material gets changed and is used inside a layered material node.
- Fixed incorrect rendering of Vectron nodes with object layer / material map nodes if connected to an OSL texture with an _sdf input.
- Improved performance in some scenes with a scattering environment medium when using RTX.
- Fixed portal material being non-transparent to shadow rays.
- Fixed clamping of HDR input values in the color correction texture.
- Fixed CUDA failure when rendering toon materials.
- Fixed incorrect rendering of toon materials with opacity < 1.
- Fixed CUDA failure when vertices of a mesh are moved around in quick succession and RTX is enabled.
- Fixed broken auto bump of vertex displacement if dirt is used in the material as well.
- Fixed missing render update if a toon ramp is modified.
- Fixed superfluous geometry updates when an input of a volume node got changed.
- Fixed specular transmission "leaking" into the indirect reflection render pass.
Happy rendering,
Your OTOY Team
Lewis
Thanks Juan, that was quick fix :).
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Rainbow-3D
Wow, so fast you were with this fix!
Now works all.
Thank you Juanjo.
Win 7 x64 | Asus P8P67-M - i72600K | 16 GB RAM | 1 x nVidia RTX 2800
Win 11 | i7 13700K | 64 GB RAM | 1 x nVidia RTX 4090
smount1
Excellent work Juan, thank you
promity
I found a bug - I tested World Creator and imported the landscape into the LW, then placed the trees on it as instances. When rendering with the denoiser enabled, some part of the instances becomes pale blue. If the denoiser is turned off, everything is in order.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
juanjgon
promity wrote:I found a bug - I tested World Creator and imported the landscape into the LW, then placed the trees on it as instances. When rendering with the denoiser enabled, some part of the instances becomes pale blue. If the denoiser is turned off, everything is in order.
Can you please export this scene to a .orbx file to try to reproduce the problem in the Standalone and report it to the core devs?
realistic-design
Hey, I have had similar problems (on trees) with octane gradient2 texture node with more than 2 keys. Are you using this node to introduce color variations on the trees? @promity, if so, try to reduce the number of keys. @juanjgon => It doesn't seem to fail anymore on this last version, at least here.
Raphael
AndyM1969
What the hell has happened to octane medium, it's taking forever to render.
batman911
Hi Juan,
I've found a bug in this latest release. I've rendered a glass bottle which has two surfaces applied, an inner and outer surface, which seems to render incorrectly. It renders fine if the glass is all one surface. However the two sided glass worked OK in release 1.4. This same problem happened at some point in last years version but it was fixed. (I think Lewis sent it to you) I also looked at it in Standalone and it has the same problem there. I've attached the scene here. Can you see how to fix this?
Cheers, Alex
Octane 2020.2.3 Double Surface Problem.zip
(288.08 KiB) Downloaded 314 times
juanjgon
AndyM1969 wrote:What the hell has happened to octane medium, it's taking forever to render.
In what version was it working faster? Perhaps there is a change in the medium or other parameters.
