OctaneRender™ for Blender 2020.2.3 - 23.5 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgraded to 2020.2.3
  • Cleared GPU resource cache when exiting Blender
FIXES SINCE LAST RELEASE
  • Fixed the Octane initialization failure when switching to a new template
  • Fixed several group input bugs
  • Adjusted max sample number from 64k to 100k
You can read about new features of OctaneRender™ 2020.2.3 here:
viewtopic.php?f=24&t=77414
1. OctaneRender™ Server
Windows
Blender Octane Edition - 23.5 (2.92)
Octane Server - Enterprise Edition - 23.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 23.5 (2.92) Linux
Octane Server - Enterprise Edition - 23.5 Linux
OSX
DOWNLOAD
Blender Octane Edition - 23.5 (2.92) OSX
Octane Server - Enterprise Edition - 23.5 OSX
