Node Editor crashing 2020.2.3
jasonloader
Every time I type into the search field in the node editor - Octane crashes. I'm running a PC Windows 10, C4D R19.
It's an old topic, grab this build
viewtopic.php?f=85&t=77426
62STARTREK
HI. I have the same issue. I've installed 2020.2.3 R3 but when I type in the Search bar of the Node Editor it causes a crash.C4D R 23.110, Win 10, graphic card drive updated. In the S 24.035 I've installed 2020.2.3 R2 and I don't have the crash typing in the Search bar
62STARTREK wrote:HI. I have the same issue. I've installed 2020.2.3 R3 but when I type in the Search bar of the Node Editor it causes a crash.C4D R 23.110, Win 10, graphic card drive updated. In the S 24.035 I've installed 2020.2.3 R2 and I don't have the crash typing in the Search bar
Are you sure? I was a temporal issue on 2020.2.3 and fixed for next builds. I don't see any crashes with 2020.2.3-R3. Send the _bugreport.zip please
62STARTREK
Yes I'm sure. I have the issue only for C4D R23.110. Here's the .zip
bugreport_20210424_102502.zip
(177 Bytes) Downloaded 141 times
jessestormer
**Following**
Same issue here
-- edit: I don't know what changed, but it's not crashing now.
Your file is empty, apply the picture for correct reports.
turtles123
i have been using octane since v2...octane just crash all the time, all version, all computers, all gpus....crash crash crash crash there is nothing you can do about it
turtles123 wrote:i have been using octane since v2...octane just crash all the time, all version, all computers, all gpus....crash crash crash crash there is nothing you can do about it
Surely that's not the same case what we're talking about. AND for you, it will not crash as you said if you're working in limits without forget it's not a cpu renderer.
